by dumper » Fri Nov 22, 2019 5:48 am
Always used to disconnect the battery leads then remove top bolt from under the bonnet then get underneath remove wireing and then the remaining two bolts and for refitting new starter put two bottom bolts back in finger tight then back under bonnet put top bolt in and fully tighten then back underneath to finish it off that was with the old large starter on the mk3&4s never had to change a mk5 smaller one but they always look easier with been so small
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
