Altransit wrote:You can LOCK any tibbe lock with ANY Tibbe key, so it may be that you've fitted the locks on the wrong doors
V184 wrote:Altransit wrote:You can LOCK any tibbe lock with ANY Tibbe key, so it may be that you've fitted the locks on the wrong doors
I thought they were pretty fool proof when fitting, colour coded and different angles relating to which door
Abcd123 wrote:On this transit I have 2 different keys, one for the. Ignition, pass door, fuel filler and the other is just for the drivers door. It has always been like this since I’ve bought the van. However the drivers door lock doesn’t unlock easily and is hard to lock as well I’ve tried WD40 and still it’s not working properly. Is there anyway to get a matching locking barrel from ford for the drivers door (I think it would be the original) as it would save me changing all the locks and keep the set original.
