bambi mk 1 wrote:Where abouts are you in Ireland I can sort you with a good engine that you can see running and drive
Tmcd wrote:HI all, Just a update. Rebuilt the head using the old valves but cleaned and reground valves, new valve stem seals. New water pump timing belt and new gaskets allround, I set valve cleareances when cold, the engine started ok after a bit. Should I run the engine till warm and then check clearances again, when listening to the engine no1 sounded a bit tight. Still smokey but I have aranged garage plates so Im going to take it for a good blast down the road to see if it clears.
