Chuggy wrote:The only hole you can see to line up without removing the front panel and rad is the Injection pump pulley one, the flywheel one is up to the right above the starter motor.
Here's a pic showing the injection pump and camshaft pinned in their correct positions.
Chuggy wrote:Dunno, I grabbed the picture from on the forum somewhere.
V184 wrote:The whole job is quite easy to do without removing the radiator etc including changing the water pump
dumper wrote:V184 wrote:The whole job is quite easy to do without removing the radiator etc including changing the water pump
Can’t see the point in not take the radiator out it’s so much easier for the little time it takes to remove and the talk screws on the timing cover can be a right game the last ones I did needed a impact wrench to remove them
V184 wrote:dumper wrote:V184 wrote:The whole job is quite easy to do without removing the radiator etc including changing the water pump
air chisel with a bit of care for the stubborn torx bolts providing you have access to one
