meerkatmag wrote:I may be wrong but I thought the early di didn't have a lift pump and later did? I've got a fuel filter housing with a manual pump on which I think was fitted instead of a lift pump.
The whine comes and goes with throttle movement. I can make it stop by moving accelerator back by a few milimieters and start again by moving it forward so I'm thinking it's injection pump as revs are barely changing surely belt would be unaffected by small movement of accelerator?
It starts suddenly at about approx 2200rpm and sounds the same as revs increase. The sound stops if i release the accelerator completely or if I put accelerator to near the floor.
Weird isn't it?
bambi mk 1 wrote:Phillips screws in the rocker cover no lift pump ,10mm headed bolts in cover lift pump Lift pump was fitted to stop them cracking pistons but didnt till they fitted Bosch pumps
V184 wrote:bambi mk 1 wrote:Phillips screws in the rocker cover no lift pump ,10mm headed bolts in cover lift pump Lift pump was fitted to stop them cracking pistons but didnt till they fitted Bosch pumps
to answer the original question i would not think not running a lift pump would cause the noise
bambi mk 1 wrote:Are you sure its not this viewtopic.php?f=4&t=188919&hilit=whistle&c=1
