Altransit wrote:I'm assuming that you mean the steel pipes Back in the day, most decent garages or even Motor Factors could make up new pipes from a pattern
Maybe it's no longer the case, or maybe you just need to seek out a more "old school" garage
Someone will be along with a better idea than me perhaps
Mislaid wrote:If looking to get them made, local hydraulic reconditioners, steering racks, rams etc should be able to make them. Cost wise, not got a clue.
I would make myself reusing any fittings if needed
Chuggy wrote:I assume you mean the fuel injection pipes, four pipes from the back of injection pump each going to one injector?
I would ask at your local fuel injection specialist.
MinorMatt wrote:Which injection pump do you have? A lucas CAV or a bosch? I have a number of these pipes on the shelf. TBH I have never heard of them failing so I don't think a 2nd hand set would be a problem
MinorMatt wrote:ok, will check what I have
Chuggy wrote:what is the link to the online ones? I'll have a look
