CHT SENSOR.2.0 DOHC PETROL.
Postby stanthevanman » Thu Jul 30, 2020 8:42 pm
CHT sensor has failed (2.0 petrol dohc engine) so the fan is constantly on..anyway to get around this ? Cos i cant find a sensor anywere..
stanthevanman
Re: CHT SENSOR.2.0 DOHC PETROL.
Postby Altransit » Fri Jul 31, 2020 1:15 pm
:idea: Put a switch in the feed to the fan controller :)
Postby stanthevanman » Mon Aug 03, 2020 8:17 am
stanthevanman
Postby Frag » Mon Aug 03, 2020 12:22 pm
Are they obselete at main dealer ?
It won’t have a cht as such,it will have and ECT,usually onto thermostat housing.
Have you code read or data logged it to confirm,as the older engine management system,EEC5 I’m guessing,
Will run cooling fan when it sees a fault or goes into ‘limp home strategy’
Frag
Ford Technician
Postby stanthevanman » Wed Aug 05, 2020 8:08 am
Yup..nothing at the main dealers,or anywere else.the sensor plugs into the block .very difficult to get at..it has a two pin grey connector (apparently the colour is important) my garage said it was a cht sensor..
stanthevanman
Postby Frag » Wed Aug 05, 2020 7:59 pm
Post or PM your reg number,
What diagnostics have led to the conclusion it’s that sensor that’s faulty ?
Frag
Ford Technician
Postby stanthevanman » Fri Aug 07, 2020 7:31 am
The garage tested the part and told me it wasnt working.mind you they tried to remove it and ripped the plug off in doing so !!. So at the moment the fan is running permently.
stanthevanman
Postby stanthevanman » Sun Aug 09, 2020 7:05 am
Does the CHT/ECT sensor operate the auto choke?
stanthevanman
Postby Frag » Thu Aug 13, 2020 6:17 pm
Done some more digging,I’m still convinced that is not the right sensor,or causing the fault.
(I’m sure that’s for the temp gauge on dash only)
But,it is still available both from Ford and aftermarket.
Part number is F3936774
https://www.ebay.co.uk/itm/273527175795
That’s the gen.ford so expensive,using that part number you will find loads of cheaper options,I.E.
https://www.ebay.co.uk/itm/333676423816
If the wires to that sender,are black with blue trace and possibly just black.
It’s for the gauge only,has no effect on engine management or cooling fan.
Frag
Ford Technician
Postby Frag » Thu Aug 13, 2020 6:25 pm
Where that sensor fits,there should be another next to it,towards rear of van.
This is engine management coolant temp sensor,(PCM then controls fans and speed via relays and resistor.)
Part number F6810428
Gen ford.
https://www.ebay.co.uk/itm/252766077173
Same again,cheaper alternatives available if you search that number...
The wires to this sensor should be white and green/brown and green.
Fault could lie with this sensor or wiring,faulty fan relays,vehicle in ‘limp’ mode or the aircon switches pulling fans in....
Etc,etc
Frag
Ford Technician
Postby stanthevanman » Thu Aug 13, 2020 7:31 pm
Yup.its the other one thats broke.the rearmost of the two.
.sadly the one whos link you sent me wont fit this plug..
stanthevanman
Postby Frag » Thu Aug 13, 2020 7:53 pm
What colour is the wiring to it’s plug ?
Have got the sensor itself out,or the broken piece ? There’s a part number on the plastic part of the sensor.
Frag
Ford Technician
Postby Frag » Thu Aug 13, 2020 8:23 pm
All the info from Ford shows the sensors,with that plug/type at the front.
The rounder type to the rear....
If that sender is broke,all that shouldn’t work is the temp gauge ?
Don’t ask me why it’s uploaded the pic sideways,click on it and it shows correctly...
Frag
Ford Technician
Postby Frag » Thu Aug 13, 2020 8:27 pm
From wiring diagrams.
These are on ETIS,and I also have the full folder on paper from ‘pre’ computer days..
Same pic on both.
Frag
Ford Technician
Postby stanthevanman » Thu Aug 13, 2020 8:53 pm
The only number i can see is.. f5af-12a646-aa 9f25g or c.its a bit hard to see..
stanthevanman
