Hello everyone
i have 98' westaflia nugget transit and its injection pump started leaking from multiple places. I decided to swap it to a bosch pump and i have been able to source 0 460 414 145 pump, throttle pedal and cable and bracket for the pump.
Before i start to tear it apart for fiting new pump, i would like to know few things if anyone has the information. It has this yellowish metal bracket thing which holds inside fuel cut off solenoid, how do i get rid of that 3 wire thing that i read somwere were useless. Do i just open those allen key headed bolts which seem to keep that bracket and then do i gain acces to solenoid? Only 12v is needed for it to make it open, ofcourse only when ignition is on? Are the pipes to injectors allready in right order or does one need to change something when fitting bosch in place of epic?
Engine is original 85ps, are the injectors fine with this pump? Anything else i have to take in consideration before going for the bosch?
Thank you in advance, this forum has lots of useful info.
-Miro
