Shuddering smiley
Re: Shuddering smiley
Postby twin wheel camper » Fri Nov 06, 2020 8:56 pm
joinerman wrote:Prop off today & gone of to be refurbed, joints were well stiff & notchy.
How much did they charge per joint?
Just curious because I also recently got one refurbished and paid £120 for a single joint and was just cross checking if the price was ok or high :D
twin wheel camper
Postby joinerman » Fri Nov 06, 2020 9:37 pm
They told me worst case scenario if they did all joints £250.
HOWEVER
Got a call lunch time to say it's totally knackered, the slip yoke splines were seized and when the got it apart the splines were twisted, in effect like a screw, it's what's caused the centre bearings to fail so quickly & buggered the U/J's, they have sourced me a brand new complete prop & should have it on Tuesday, eye watering price but it's a working van, got to do it.
joinerman
Postby Adam mk1 » Fri Nov 06, 2020 10:54 pm
This hope they've got you the correct prop, a mk5 lwb 100 is quite a rare van, so its a 5 stud axle, the prop needed, is specific to the 100 lwb, most lwb are ether 150 or 190 6 stud single wheel and they use a different axle and distance from front of axle to gearbox is different
Adam mk1
Location: Live in southsea Portsmouth, work nr Winchester
Postby Adam mk1 » Fri Nov 06, 2020 10:58 pm
Adam mk1 wrote:This hope they've got you the correct prop, a mk5 lwb 100 is quite a rare van, so its a 5 stud axle, the prop needed, is specific to the 100 lwb, most lwb are ether 150 or 190 6 stud single wheel and they use a different axle and distance from front of axle to gearbox is different
When u say its a 100 i presume you mean the weight it can carry not the horse power
Adam mk1
Postby joinerman » Fri Nov 06, 2020 11:06 pm
Mines a 100 model running on 15" wheels 6 Stud.
joinerman
Postby Adam mk1 » Fri Nov 06, 2020 11:16 pm
100 do you mean horse power, became if its 6 stud 15 inch wheels that was only available as a 150 weight or a 190 weight, if its 6 stud 15 inch single wheels as you say thats the more common prop, number on vin tag top right is the one
Adam mk1
Postby joinerman » Mon Nov 09, 2020 9:51 pm
New prop arrived this morning, this one has circlips so U/J s can be changed, also it has grease nipples. fitted this afternoon & it's transformed the drive of the van.
joinerman
Postby Chug » Mon Nov 09, 2020 11:00 pm
Sounds like a decent prop, how much was the eye watering price and who was the company who supplied it?
Chug
Postby joinerman » Mon Nov 09, 2020 11:17 pm
£504 inc vat Chug, don't know the company who supplied it, the place i took it to in Wycombe sourced it.
joinerman
Postby Chug » Mon Nov 09, 2020 11:39 pm
Cheers, What was the place in Wycombe that got it for you?
Chug
Postby joinerman » Tue Nov 10, 2020 10:00 pm
Pm me Chugg
joinerman
