by Adam mk1 » Tue Nov 17, 2020 4:26 am
not an easy job if your not a hands on man, garages think of time and it could go wrong unless its done in certain way and not rushed with poor fitting sockets & ham fisted inpatients, id remove air filter to give better access, id use an angle grinder with a 1 mil cutting disc (dont use if in experienced) they can kick back and take your fingers off, id cut through excess thread of bolt, the heat from grinder may help a bit, there 13 mil spaner size bolts, try beating a 1/2 socket on nut, if that fails cut across bolt with grinder splitting nut in half, the idea of this is to remove manifold and replace manifold studs, once manifold is removed, if studs shear at head then head will have to come off anyway but id try this first, i had a similar problem with a Bentley all bolts we're rusty and access was tight, i had to remove steering column to get grinder under manifold, and then i placed grinder were i wanted it, put my gloves on full face mask, lay under car, then flick the switch and hold on to that grinder, cut bolt switch grinder off, let it stop, then remove grinder, took me 2 afternoons to get it off, im a panel beater and welder by trade, and have been using grinders for over 30 years, so my advise is dont buy a grinder and have a go, let some do it that knows what there up to
