Mk5 2.5 turbo compression test
Postby powercrazymark » Thu Nov 19, 2020 8:46 pm
Hi does anyone know what figures I should be looking at getting from 2.5 di turbo engine compression test? And what the lowest acceptable figure is? I know there should be no more than 10% difference between cylinders but what should I be getting?
powercrazymark
Re: Mk5 2.5 turbo compression test
Postby gotgcoalman » Thu Nov 19, 2020 9:01 pm
Using a calibrated tester or off the shelf diy job?
If it's diy then take the max reading with a pinch of salt,but the 10% spread will still apply.
Sent from my Plus E using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby powercrazymark » Fri Nov 20, 2020 8:00 pm
Calibrated tester with the proper dummy injector and seals
powercrazymark
Postby Keef » Sat Nov 21, 2020 12:49 am
I did one of mine recently, I'm pretty sure the data was in the Haynes manual but I haven't got one here to check.
Keef
Postby Chug » Sat Nov 21, 2020 1:02 am
I've got 31 bar/450 psi in my head and anything below 25/26 bar is getting bad but I'm sure I have the correct figures somewhere.
Chug
Postby powercrazymark » Sat Nov 21, 2020 6:20 pm
So if what chug says is correct then we can assume that 245psi with no oil in the bores and 280psi with oil in the bores is definitely too low. Highest reading I can get is 300 psi with oil down the bore and there is definitely 10% variation on the cylinders
powercrazymark
Postby powercrazymark » Tue Nov 24, 2020 10:12 pm
Can anyone confirm correct figures?
powercrazymark
Postby dumper » Tue Nov 24, 2020 10:18 pm
Is the turbo engine lower compression then the non turbo I think I’ve seen it somewhere.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby powercrazymark » Tue Nov 24, 2020 10:26 pm
Yeah the turbo engine has a lower compression ratio than the non turbo engine.
powercrazymark
Postby gotgcoalman » Tue Nov 24, 2020 11:04 pm
Is the spread within 10%
gotgcoalman
Postby powercrazymark » Tue Nov 24, 2020 11:07 pm
No its not within 10%
powercrazymark
Postby Chug » Wed Nov 25, 2020 12:38 am
I still cannot find any info to confirm or refute that figure, even had a search with no luck so maybe I dreamt it :lol:
but it sounds similar to other diesel engines, and with your low readings and if there is a lot of variation between cyls then it's probably poorly.
Chug
Postby powercrazymark » Wed Nov 25, 2020 12:10 pm
I think it is poorly with the variation but just wanted to know how much lower it was than what it should be
powercrazymark
