by Fordtractorman » Tue Dec 01, 2020 6:24 pm
The EPIC saga continues.
So far-
Removed old fuel filter.
Whilst filter off, I took the opportunity to check cam belt timing- so removed flywheel speed sensor, rotated crank until i found the 'All the way through flywheel' 13mm hole. Then removed little rubber bung in front of inj pump gear. Had a look in there and the slot lined up perfectly. Inserted a drill bit in there also. Fitted great. So the timing cant be too far off. I have a new belt + tensioner on order, and will put it on this week.
Removed all drill bits and re-assembled area. Fitted new genuine Ford fuel filter. Swapped over old fuel in water sensor and new flat seal o-ring off new filter in base. The silly three dimple, push up, and thread on black plastic round neck collar idea filter. I do hate these. Removed and re-fitted twice to be sure it was seated. It seemed to be. Black plastic locking collar was screwed up tight ALL THE WAY ROUND CIRCUMFERENCE as it should be. Pointer scribe line in plastic also aligned correctly.
Every one says these filter systems (1997-2000) are self bleeders. Even Mr.HAYNES!! But ive learnt over the yrs to take what Mr.Haynes says with a pinch of salt!!! Sometimes he talks boll*cks!
Eventually got engine started. This van has two 642 batteries. Each being 1000 CCA. So we have plenty of speed at starter motor. Engine had a little cough for a sec or two, but soon cleared. After 5 mins of smooth running, she developed a slight miss fire/ slight hunting. Left run for another 20 mins, on various revs, but the slight miss was still there. Left her ticking over for 30 mins. Hunting got much worse by now. Left her run. Opened fuel tank cap with other key, incase of any vacuum/tank issues. No change.
No visible leaks anywhere. Continued to let her run. Hunting got so bad, she stopped on her own. So keyed off. Let her 'calm down' for 10 mins. Tried to re-start, but no sign of firing. Turning over plenty of speed, but not attempting to fire.
So day latter, i disconnected both push fit fuel pipes off lift pump. Got compressor and blew down pipe leading back to fuel tank. Several long bursts and plenty of bubbles in tank. I never let tank drop below half full, as ive heard many horror stories about this! Tank is currently 95% full. Re-fitted pipe back onto outermost port (suction) of lift pump. Assistant cranked engine. Plenty of strong squirts of fuel. Lift pump has only done 2000 miles. So reconnected red (Innermost) connector on lift pump. Followed that pipe up round back of head and unplugged it from fuel filter hsg. Got assistant to crank engine. Again, good bubble free squirts present.
Ive heard lots about the silly fuel filter hsg going wrong. Those four silly female push fit connectors are just begging for trouble! So to eliminate that, i removed the whole lot. Then connected up the four male fuel pipes with two short lengths of 7.5mm fuel hose, to bridge the gap. Then unscrewed the male union on the feed (Front) pipe going directly into inj pump. Got assistant to crank engine. Good strong spurts coming out of pipe. Reconnected union. Then unscrewed the union next to it (exit/return from inj pump) and got assitant to crank engine. Good spurts coming from there. Re-connected union.
Next, cracked off injector pipes 4, 3 and 2. Got assistant to crank engine. NO FUEL THERE. Attempted to crank engine for 10 sec bursts every 20 mins through out day, whilst monitoring starter motor + leads temperature. Still no sign of good strong squirts of fuel from injector pipes.
Has my EPIC injection pump got so confused after several dozen/maybe hundreds of rotations of flywheel, but not actually fired?? This can happen on some other makes. System doesnt know what is going on by now. Have left it for today, with earth leads removed from batteries to try and hopefully let EPIC system/ECU rest itself. Im told this SOMETIMES can help.
Im not sure what to think now. Have i got EPIC system issues? Until engine starts i cant say yes or no to question of- Red engine management light on dash on or not? Its always on during cranking. Thats how they are. I must confess, in the 15 odd years ive owned this van, that light has never once come on/flickered, during normal driving. Yes the bulb works! This van is extremely original. No bodging. Im only the second owner. First was environmental agency, who always used Ford dealerships.
This is the first time in 120,000 miles that the EPIC system has let me down. So they cant be that unreliable.
Have i missed something in bleeding?
Calling all EPIC fans for ideas!
