by Noctule » Thu Feb 04, 2021 12:23 pm
When did it start doing this? Have you had the door off, or have you bought it like that, or has it happened over time?
It would help to grease the top latch, if the pin and hole are corroded they won't slide.
You should also check the body where the door seal is pulled up to for corrosion. The door seal is likely to be quite stiff (it'll have had it's 21st birthday) making it harder to make a water tight seal, and if the body is starting to blow it'll make it harder for the door to pull up tight. A bit of vaseline or silicone spray on the seal will help.
Then you can go about actually adjusting the door.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
