MinorMatt wrote:A small amount of petrol in the diesel is ok, whatever the pump.
bambi mk 1 wrote:Before you go at it like a Jack Russell burying a bone remomove the valve cover and check fo a loose bolt, classic symptoms and nothing to do with the fuel system
Altransit wrote:bambi mk 1 wrote:Before you go at it like a Jack Russell burying a bone remomove the valve cover and check fo a loose bolt, classic symptoms and nothing to do with the fuel system
OMG you're back
Welcome home buddy
Altransit wrote:Turbo engine with a Lucas EPIC pump?
MinorMatt wrote: I would do is take the fuel filter off, drain whats in there, put a splash of mineral 2 stroke oil in and top it off with diesel and start it up.
bambi mk 1 wrote:remove the valve cover and check fo a loose bolt, classic symptoms and nothing to do with the fuel system
dumper wrote:A 1999 is a mk5 mate it will be a banana engine
gotgcoalman wrote:Change filter/drain tank of piezel. (Petrol diesel mix)
Bleed system and good to go
