hi
whats the benifit of blanking the egr valve on a 2.5 engine? thanks george
wojciech wrote:The advantage is that not only will you not have to take care of him, but even think. Due to sediments, EGR can block, it does not close completely, the engine then loses power, jerks, strongly smokes black.
It is vacuum controlled, so you just need to disconnect the vacuum rubber pipe from the EGR and the EGR will be constantly closed.
The disconnected pipe should be closed so that it does not suck "false" air into the inlet. That's it - 10 minutes of work.
