Which brake pads for my 1987 mk3
Postby Pdiddybigbear » Tue Mar 23, 2021 2:57 pm
Hi all :)
My transit is a mk3 2.5 di 1987 and i need new brake pads, its currently up on ramps and to save the fuss of getting it down to jack it up to remove the wheels to check what pads does anyone know what shape of pads i need before I buy them as there seems to be multiple to pick
Thanks,
Check out my video diary of the Van here: https://www.tiktok.com/@ourmotorhomelife
Pdiddybigbear
Re: Which brake pads for my 1987 mk3
Postby MinorMatt » Tue Mar 23, 2021 4:17 pm
There are multiples to pick and there are at least 2 at that age.
Is it a lwb or swb?
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Pdiddybigbear » Tue Mar 23, 2021 5:13 pm
MinorMatt wrote:There are multiples to pick and there are at least 2 at that age.
Is it a lwb or swb?
Erm not 100% sure ahaha
Pdiddybigbear
Postby Noctule » Tue Mar 23, 2021 5:52 pm
A twin wheeler, nice.
That's a rather swanky looking set of rims you've got there. 8)
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Pdiddybigbear » Tue Mar 23, 2021 7:53 pm
Noctule wrote:A twin wheeler, nice.
Mat
Aha thank you, they came with it and are a right pain to take off ahaha another reason why I'm asking about brakes rather than just looking aha
Pdiddybigbear
Postby Noctule » Tue Mar 23, 2021 9:22 pm
Looking at Catcar.info you have a choice of two, depending on whether you have 2 pot or 4 pot calipers. You'll need a look at the caliper to see which.
http://catcar.info/ford/?lang=en&l=bWFy ... OTM2KzA%3D
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby MinorMatt » Tue Mar 23, 2021 9:56 pm
They will be 4 pot.
4 pot is LWB (6 stud wheels), 2 post is SWB (5 stud)
93 L GL Minibus
Postby Noctule » Wed Mar 24, 2021 12:29 am
MinorMatt wrote:They will be 4 pot.
Something learnt :D
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Pdiddybigbear » Thu Mar 25, 2021 9:12 am
Sorry for how daft i'm being here but which ones go to the 4 pot ones ? I cant understand Catcar :(
Pdiddybigbear
Postby MinorMatt » Thu Mar 25, 2021 9:14 am
Fairly sure its none of those (by the shape)
Just go to a proper motor factor and you should get the right ones - will be cheaper too
93 L GL Minibus
Postby MinorMatt » Thu Mar 25, 2021 9:27 am
Brembo Part no appears to be PA6001
104.9mm wide x 18mm thich, 74.7mm tall, lockheed system.
Looks like the bottom 2 in the euro's listing.
Same Pads as Landies use (their part no is RTC3273, RTC3279 or STC2956)
93 L GL Minibus
