cherniy_chack wrote:First you need to know which high pressure fuel pump is installed on your engine.
It could be Lucas CAB or Bosch.
If there is a Bosch, then a low pressure fuel pump is installed under the exhaust manifold.
If there is no Lucas booster pump.
Further steps depend on the type of high pressure pump.
