Mk5 diff leaking
Re: Mk5 diff leaking
Postby dumper » Wed Mar 31, 2021 8:42 pm
Have a look at somewhere like Halfords there maybe a inbetween size .
to get it out without you may be able to use a small pair of stillsons or try knocking it round with a chisel as a last resort knock a bolt in to it and weld it to the plug the heat of welding helps as well .
if you damaged it getting it you can get a new one from grahams plumbers merchants or similarities the past I’ve used one with a external square.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Mac1984 » Wed Mar 31, 2021 8:51 pm
thanks for your reply.
to be honest, a lot has to do with the akward height as well, the van is just sitting on the road.
should be alot better if it was on a lift
1996 2.5TD Bosch Mod, Bio degradable Body from factory but outlived its manufacturing plant.
Mac1984
Postby Chug » Wed Mar 31, 2021 9:32 pm
In similar situation I've used 3/8 drive with a bit of flat bar pushed in next to it to pack the gap
Chug
Postby Mac1984 » Wed Mar 31, 2021 10:02 pm
Thanks Chug, im sure I find a way.. Its just to determine what Shape that actually is.. I think somebody tried before, many moons ago :-)
In worst case, there is always the blue spanner..
It can't be tight, if its liquid :twisted:
Mac1984
Postby Chug » Wed Mar 31, 2021 11:28 pm
I've never known axle or g/box plugs to be that tight
Chug
Postby Mac1984 » Wed Mar 31, 2021 11:31 pm
That plug is like welded on. I had managed to put a lever in there, and the lever started bending, and that plug did not even think of moving. The material inside the plug started to give though. It's mad..
I think I will try and get a welder, and see if I can weld like a 1/2 extension on, and then get the famous Brutus Bar out.
Mac1984
Postby enfys » Sat Feb 05, 2022 4:39 am
Hi,
How did you get on in the end with that rear diff as think I'm going to try and replace or top up oil on mine as there's a bit of a rumble, but thinking I'm going to have a similar problem.
Cheers for your time.
enfys
Postby Mac1984 » Fri Apr 22, 2022 1:42 pm
Sorry for not replying to the last question. I have only seen this now.
How did I get on with this problem?
I just drilled trough the plug :-)
After all the flushing out and refilling with new oil, I just fitted a plastic blind plug in a fitting size that sits in the newly drilled opening, has not fallen out since.
Mac1984
