Safe Car Ramps...
Safe Car Ramps...
Postby Heathen » Wed Mar 31, 2021 8:22 am
If I had a pair of car ramps, rated at 750kg each, would they hold up the front of my Van?
...and not collapse and crush me.
Heathen
Re: Safe Car Ramps...
Postby straydog » Wed Mar 31, 2021 8:35 am
If the question was would I use 750kg ramps, the answer would be a definate NO.
I use Rino ramps, rated at 1350kg.
Better safe than sorry IMHO.
https://www.ebay.fr/itm/192835622759?mk ... 00_297_144
CVD 8)
straydog
Postby Pdiddybigbear » Wed Mar 31, 2021 11:16 am
Mine current lives on ramps similar to the link below and had done for a few months now. no issues, I have just put some axel stands under it just in case :)
https://www.ebay.co.uk/itm/294054861126 ... 3QQAvD_BwE
Check out my video diary of the Van here: https://www.tiktok.com/@ourmotorhomelife
Pdiddybigbear
Postby Heathen » Wed Mar 31, 2021 9:51 pm
Thanks for the replies.
I know it's not common sense to be doing an oil change when the van isn't level, but it's literally thousands of km's overdue for one, and I don't have many options.
Heathen
Postby Chug » Wed Mar 31, 2021 10:47 pm
I've used the same ones as pdiddywiddy no bother
Chug
Postby Keef » Wed Mar 31, 2021 11:07 pm
You don't need ramps to do an oil change on one of these, there's plenty of room with it on the ground.
Keef
Postby Heathen » Thu Apr 01, 2021 12:49 am
Chug wrote:I've used the same ones as pdiddywiddy no bother
2 Tonne capacity - combined? So 1 Tonne each? I find these ratings a bit ambiguous, especially when it's a shop trying to shift them.
I realise that there's good ground clearance, but the ramps will be used for other repairs/maintenance in the future, and I have a couple of other vehicles (the van being the heaviest). I want ramps to cover all bases.
Heathen
Postby Chug » Thu Apr 01, 2021 9:16 am
The whole van isn't much more than 2 tonnes so the front or rear will be much less, but just get some 2.5 or 3 tonne heavy duty ones if you are worried, or weld some strengthening metal into the 2 tonne ones.
Chug
Postby Pdiddybigbear » Thu Apr 01, 2021 9:43 am
My drive way slopes down towards the garage so there ramps actually make it level :) There is clearance without ramps but as someone who is currently pulling his hair out trying to get my sump off... the more room the better :) Plus if its over due an oil change you will want room to get the pesky sump nut off.
Pdiddybigbear
Postby gotgcoalman » Thu Apr 01, 2021 7:50 pm
As said.
Either get the higher rated ones or reinforce the others.
I've had a cheap set slowly collapse once a van was on them.
Sent from my Plus E using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby Heathen » Sat Apr 03, 2021 7:56 am
Job done.
I lay down some decking boards, put some weights plates on top of that. It gave me an extra, luxurious, ~2.5" of clearance.
...and what a pleasure the sump plug was. I think it's a lead/playdough alloy.
Heathen
Postby yakob » Thu Apr 29, 2021 8:56 am
Slightly late to the party - but my only ramps are rusty and old and rated to god knows what. They don't give me loads of confidence so I stack bricks under the flat where the wheels sit and stick some chunky logs in under the incline. It's worked fine so far
Mk6 2.0 Di FWD
2005
yakob
Postby man le-mans » Mon May 03, 2021 7:24 pm
Heathen wrote:If I had a pair of car ramps, rated at 750kg each, would they hold up the front of my Van?
750kg each so a total of 1500kg for the pair to lift just the front of the van, I would say is safe. As said it’s no more than 2 tons total
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby gotgcoalman » Mon May 03, 2021 9:09 pm
Remember the 750kg ramps are Chinese rated.
gotgcoalman
Postby brickent » Mon May 10, 2021 9:06 am
I have Rhino Ramps also. They are very heavy-duty.
brickent
