Rear shock question :)
Postby Pdiddybigbear » Sun Apr 04, 2021 2:13 pm
Hey, I need to replace one of my rear shocks on my mk3 chassis cab motorhome conversion.
I’m a big believer in upgrade don’t replace (where possible)
Can anyone suggest a stronger or uprated shocks that I can fit rather than the standard mk3 ones ?
Thanks in advance
Check out my video diary of the Van here: https://www.tiktok.com/@ourmotorhomelife
Pdiddybigbear
Re: Rear shock question [emoji3]
Postby Boltrounder » Sun Apr 04, 2021 3:23 pm
Did you find better ones?
Boltrounder
Postby Pdiddybigbear » Sun Apr 04, 2021 3:36 pm
Boltrounder wrote:Did you find better ones?
Ahah nope
I’ve only just asked though, hoping someone on here has good advice :)
Pdiddybigbear
Postby Boltrounder » Sun Apr 18, 2021 11:41 pm
Guessing this thread died a death
Boltrounder
Re: Rear shock question :)
Postby Altransit » Mon Apr 19, 2021 9:52 pm
If you're setting up the suspension of a race or rally car, I can see that fitting uprated dampers would have some sort of effect on the performance of the car, but on a Transit van, they just need to damp the bounce of the spring, a cart spring, chosen for their load lugging ability, not their performance.
Fitting new, unworn dampers, will be a major upgrade in itself, they are one of those components that you don't notice how much they deteriorate, until you fit new ones :? :mrgreen:
Postby Boltrounder » Mon Apr 19, 2021 11:09 pm
I had a bmw e92 and hated the ride, when I was checking it over the rear damper had sh*t itself and there was no juice in it, whacked on a new pair and it was a different car.
Boltrounder
Postby Mislaid » Tue Apr 20, 2021 11:34 am
Generally speaking, use a known brand and they'll work better for longer.
Mislaid
