Turbo conversion oil feed fittings.
Postby bigg1115 » Sat Apr 10, 2021 8:07 pm
Hi guys.
I'm currently collecting turbo conversion parts for my 2.5 di banana.
I thought i had everything. But upon checking the oil feed pipe. I realised I don't have the small connector which the pipe would bolt to when removing the bung under the exhaust manifold.
(Hope that makes sense lol).
So have no way of bolting the oil feed pipe to the engine block.
Could anyone point me to where I would get the fitting from?
Or how people manage to feed there turbo with oil .
Thanks everyone.
bigg1115
Re: Turbo conversion oil feed fittings.
Postby bigg1115 » Sun Apr 11, 2021 8:09 pm
bigg1115
Postby Chug » Sun Apr 11, 2021 10:55 pm
I think most people fit a tee into the oil pressure switch fitting coz the bung under the exhaust is a pain to do, but a quick search suggests it maybe 1/4 npt?
Chug
Postby Noctule » Mon Apr 12, 2021 1:08 pm
Catcar says the size is 14mm x 1/4, part number 6518104
This part is available on eBay from Ford (expensive), but you should be able to get the part from anywhere with a good range of hydraulic or plumbing fittings. Take the bung and the pipe with you to get the right match.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby MinorMatt » Mon Apr 12, 2021 1:52 pm
Noctule wrote:Catcar says the size is 14mm x 1/4, part number 6518104
Mat
If you could point out anywhere that sells the adaptor that would be great - I haven't been able to get hold of them for a long time.
Not sure if the 1/4 is BSP or JIC (I suspect the latter)
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
