One bolt missing on the rocker arm! How do I get a new one?
Postby mkgld » Tue May 04, 2021 8:41 pm
Hi!!
Trying to solve a really bad issue of white smoke and the van overacerlerating randomly, I am checking some things that the users suggested here.
Now I was doing the valve clrearance and I have found out that there is one bolt of the rocker arm shaft missing and another one totally loose, almost falling.
No Idea where did that missing bolt gone, and that scares me.
But I will need to buy a get one.
Can anyone please tell me where can I check the right size or part number, and where can I buy it?
Thanks!!
mkgld
Re: One bolt missing on the rocker arm! How do I get a new o
Postby dumper » Tue May 04, 2021 8:56 pm
I can’t remember if it’s a special bolt or not but I would remove the rocker shaft and push rods use a pice of cardboard make some holes to put the rods into so you can keep them in the same order to go back in and the get magnet on a sick you can get telescopic ones from tool shops and stick it down all the holes in the head . Usually they land on top of the head and don’t go down into the sump have a good look round it may be still there.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby mkgld » Tue May 04, 2021 10:09 pm
dumper wrote:I can’t remember if it’s a special bolt or not but I would remove the rocker shaft and push rods use a pice of cardboard make some holes to put the rods into so you can keep them in the same order to go back in and the get magnet on a sick you can get telescopic ones from tool shops and stick it down all the holes in the head . Usually they land on top of the head and don’t go down into the sump have a good look round it may be still there.
Thanks!
I did the valves clearance four years ago and I don't know if that bolt was there by then.
I have never removed the rocker shaft and push rods and I must admit it sounds a little intimidating.
Can you point me in the right direction?
Trying to find info in the forum with no luck.
I already have that mighty life saver telescopic magnet.
Thanks!
mkgld
Postby dumper » Wed May 05, 2021 5:33 am
It’s just remove the the I think 17 mil bolts at the top of the posts and at the bottom on some of the posts they’re is a 13 mil bolt then it just lifts off and as I say keep the pushrods in the same order they come out but before you remove it have a good look around it maybe hiding on the top in a recess covered in oil.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Altransit » Wed May 05, 2021 10:19 am
dumper wrote:before you remove it have a good look around it maybe hiding on the top in a recess covered in oil.
As Dumper says, most of these are found hiding up top, get your latex glove on and have a dig about :mrgreen:
Postby V184 » Wed May 05, 2021 3:06 pm
mkgld wrote:Hi!!
Thanks!!
i think there the same dimension (6mm) as the rocker cover bolts?
V184
Postby mkgld » Wed May 05, 2021 7:35 pm
dumper wrote:but before you remove it have a good look around it maybe hiding on the top in a recess covered in oil.
Hi, today I found pictures of the last lime I did the valve clearence four years ago and that screw was missing, so must be missing for a long time.
Anyway I had a better look and pass the magnet around without removing the shaft and I could´t find it.
I removed one of the remaining bolts and don´t see how they could fall into the holes, they are too big. Or I am missing something?
Thanks !
mkgld
Postby mkgld » Wed May 05, 2021 7:38 pm
V184 wrote:i think there the same dimension (6mm) as the rocker cover bolts?
Today I compared them and the shaft bolts are a little bit longer, but I have not measured them yet.
mkgld
Postby mkgld » Mon May 10, 2021 3:34 pm
Does anyone knows where can I order this bolt online in Europe or Uk?
I live in a small town in the Alps and I could´t find it here...
Huge Thanks!
mkgld
Postby MinorMatt » Mon May 10, 2021 3:43 pm
The parts catalogue suggests the bolts should all be the same length....
Ford part no is 4380670. Its an M6x16mm flanged bolt - any hardware shop should have one (although you will want a washer to go with it - if its not flanged like the original ones). If you can only get a longer one, put a nut on it and cut the excess off (nut will keep the cut square and clean any swarf which will stop it screwing in easily...
Or look on ebay for 4380670 (its used in lots of applications - e.g. thermostat housings) as well as the rocker shaft, so don't be too put off by the descriptions
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby MinorMatt » Mon May 10, 2021 3:44 pm
Or if you can wait a few days for me to get to the workshop - I will post you a used one
93 L GL Minibus
Postby mkgld » Mon May 10, 2021 4:05 pm
MinorMatt wrote:Or if you can wait a few days for me to get to the workshop - I will post you a used one
Wow, just wow... Thank you so much.
I am always surprised with the generosity that we breath in this forum.
If I ever buy another van, will be a transit, just to be part of this familly!
mkgld
Postby MinorMatt » Mon May 10, 2021 4:11 pm
It will be cheaper to find something locally (probably even at a ford dealer) than the postage cost though...
It looks like they are about £1 new at Ford
93 L GL Minibus
Postby mkgld » Mon May 10, 2021 4:19 pm
I already asked in the only workshop in town and they can´t or don´t want to help me, but I will call a few places around, I will let you know how that goes.
I really don´t care if I have to pay more than what it really cost for the shipping, just to go to another town cost me around 20 euros, and a few hours, thats how isolated I am.
Thank you so much!
mkgld
Postby Altransit » Mon May 10, 2021 4:25 pm
mkgld wrote: If I ever buy another van, will be a transit, just to be part of this familly!
It's always nice if people who come here to solve a problem, stay afterwards to share what they've learned with the next person 8) :D
