Wiring locations ignition
Re: Wiring locations ignition
Postby Altransit » Sat May 08, 2021 9:34 am
This was mine, for comparison.
Postby gsc1ugs » Sat May 08, 2021 10:19 am
Thxs for pic and the one next to battery is normal on mine?
gsc1ugs
Postby gsc1ugs » Sat May 08, 2021 1:46 pm
Update, I sent a fused connection from the battery to the thick red on the ignition and the van had power lights, hazards everything, what does that tell me please to look at next, the red going to the ignition is not live? I even unlocked the door with key ignition on
Also, i noticed your fuse box as fuses bottom right where mine hasnt>?
gsc1ugs
Postby gsc1ugs » Sun May 09, 2021 11:52 am
The van runs forcing power to the ignition switch and everything works, i have an inline 30amp fuse just in case but van is running but i need know why power is not going to ignition in the normal way
gsc1ugs
Postby Chug » Sun May 09, 2021 9:59 pm
Here is a guide for the main fusebox https://www.autogenius.info/ford-transi ... x-diagram/
If the main red ign wire has no power, is there power to and from the two fusesbox near the battery?
Chug
Postby gsc1ugs » Mon May 10, 2021 7:52 am
Hi chug do you mean this fusebox?
gsc1ugs
Postby Chug » Mon May 10, 2021 8:03 am
Yes that one, check for power through fuses and give it all a good clean.
Chug
Postby gsc1ugs » Mon May 10, 2021 9:00 am
All 3 empty slots 12.4v the first fuse that dont pull out 12.4 v the yellow none
gsc1ugs
Postby gsc1ugs » Mon May 10, 2021 11:13 am
60amp fuse blown next to battery
gsc1ugs
Postby MinorMatt » Mon May 10, 2021 11:34 am
So almost sorted then...
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby gsc1ugs » Mon May 10, 2021 11:44 am
Working - solved - thxs to all for push
gsc1ugs
Postby Chug » Mon May 10, 2021 10:25 pm
Glad to hear that you've sorted it 8)
Chug
