by Chug » Sun May 09, 2021 10:18 pm
If the pin holes in the flywheel, camshaft and injection pump all line up then everything is in the correct position, it will need fine tuning using the four bolts in the centre of the pump pulley, they have elongated slots to allow movement.
You wont turn the pump by hand it will need a spanner and some pressure to overcome the pumps cam lift.
