Check the blink codes mate, otherwise you could spend an awful lot of money and still have the same problem. Get that code and report back
The most common immobiliser problem is the fuse or relay in the auxillary fuse box under the bonnet. Being an auto there are several in the box, so check all the fuses and swap the relays around.
I have no problem posting bits to New Zealand if you need them - but its not practical to come over from the UK to check it out really
That ECU number means nothing - its how its programmed that matters. Thats ECU can be programmed as manual/auto, any power output etc
I don't rate your auto sparks... 3 wire is non turbo and not an age thing. Lets hope they haven't put 12V on to the stop solenoid plunger and blown it...
As for their suggested parts list - its wrong. You need the ECU, PATS module and Keys (if you have an immobilised van) or just the ECU (and that 50mm long piece of wire) if you can find a non immobilised one.
Get the blink code and we (or at least I) can advise further
Matt
www.facebook.com/transitionclassicsLucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
