dumper wrote:Has it had the injector leak off mod done mine started doing it intermittently till I did it also when did you give the engine a service fuel/air / oil & filter
dumper wrote:No it’s the return pipe you change it’s just a matter of moving the end bung from no 1 to no 4 and extending the return pipe to no1 I’d also get a new end bung as mine split removing it I did a temporary job of putting a round nail up a piece of return pipe to block it .
Keef wrote:Sounds like it's fighting for either air or fuel.
If it's air it could be blocked air filter or inlet manifold full of egr gunk?
If it's fuel it could be fuel filter or maybe drawing air into the fuel somewhere?
camper-man wrote:dumper wrote:No it’s the return pipe you change it’s just a matter of moving the end bung from no 1 to no 4 and extending the return pipe to no1 I’d also get a new end bung as mine split removing it I did a temporary job of putting a round nail up a piece of return pipe to block it .
I was told only do the leak of mod if its running bad on tickover but i will do that tomorrow as well as changing the filter and see what happens
Anyone know the best place to buy new pipe and what size it is?
V184 wrote:camper-man wrote:dumper wrote:No it’s the return pipe you change it’s just a matter of moving the end bung from no 1 to no 4 and extending the return pipe to no1 I’d also get a new end bung as mine split removing it I did a temporary job of putting a round nail up a piece of return pipe to block it .
Thats correct . more likely if you haven't a fuel supply problem etc is the torque sleeve sticking in the injection pump
