bambi mk 1 wrote:
If you were clever like Al you would have posted the link
i will remember that next time
gotgcoalman wrote:Fish tank silicone air pipe works well as leakoff pipe
Sent from my Plus E using Tapatalk
dumper wrote:I can’t remember witch way to screw it in or out but we used to adjust them as far as we could with as much black smoke as we could get a way with and with it been a works van we adjusted the throttle stop to get more revs out of it but not recommend doing it to your van
dumper wrote:The pump will have been setup originally on a test rig from what I’ve been told some settings are set as they assembled it but that maybe bulls@@t from when I had my mk3 di done when it was very underpowered after a exchange pump if it was mine I’d find out which way to increase the fuel and make it smoke and then back it off till you get a acceptable level of smoke Back when the mot smoke test at ministry test centres the 190 lwb and the A series to get them through the test we had to turn them down that much that they struggle to get out of the brake rollers as it really reduced the power .
dumper wrote:If I remember correctly it’s mark up 12 degrees on the pump and 13 degrees in the gen Ford workshop manual that was on the early pump that had degrees marked on the pump drive the later one had a fork arrangement but I can’t remember how we set them up you either lined them up or offset them.
camper-man wrote:k am lost with this i have changed the filter housing and filter "This came as a complete unit" Turned the pump up till started to get black smoke and turned it back abit,But something is still not right am thinking top could be the the injectors or the pump Is anyone local to the north west that could have a look at this for me.Thanks
bambi mk 1 wrote:dumper wrote:If I remember correctly it’s mark up 12 degrees on the pump and 13 degrees in the gen Ford workshop manual that was on the early pump that had degrees marked on the pump drive the later one had a fork arrangement but I can’t remember how we set them up you either lined them up or offset them.
Ya thinking of a Yorkie
