Transit mk5 2.5 non turbo UNDER POWERED
Re: Transit mk5 2.5 non turbo UNDER POWERED
Postby camper-man » Sat Jun 19, 2021 12:28 am
V184 wrote:
camper-man wrote:k am lost with this i have changed the filter housing and filter "This came as a complete unit" Turned the pump up till started to get black smoke and turned it back abit,But something is still not right am thinking top could be the the injectors or the pump Is anyone local to the north west that could have a look at this for me.Thanks
Why dont you check the torque sleeve :? theirs a link to it on this thread somewhere :lol:
I am abit worried about doing that job as i have never done it and i dont want to make a balls of it and the vans off the road completely.
Can you still buy a new Torque sleeve?
camper-man
Postby camper-man » Tue Jun 22, 2021 2:43 pm
Has anyone change the TORQUE SLEEVE and if so where can i buy one.Thanks
camper-man
Postby V184 » Tue Jun 22, 2021 4:32 pm
camper-man wrote:Has anyone change the TORQUE SLEEVE and if so where can i buy one.Thanks
You maybe able to clean the bore of the sleeve with fine paper , i used to use snap ring pliers to remove it from the pump :wink:
V184
Postby vanfox » Sat Jul 03, 2021 11:22 am
Just reaching for tin hat.......search for torque sleeve, I posted a couple of pics with a bolt in it to withdraw it and before and after cleaning, Jan 2019 ish.
My first van was a petrol, I had some fun with the ignition timing, ha! Got me thinking, is a diesel in any way similar, injection advance and retard.
The pump is bolted to the drive flange.I pinned the motor, slightly loosened the 4 bolts and replaced the pump pin with a slightly thinner drill, used the front nut on the pump to advance the pump in relation to the drive flange. Tightened the four bolts, removed all the pins and started the engine. It seemed just a touch brighter and seems to pull a bit better. Maybe it will help your sluggish motor, or not. Worked for me.
vanfox
Postby Altransit » Sat Jul 03, 2021 11:48 am
vanfox wrote:Just reaching for tin hat.......search for torque sleeve, I posted a couple of pics with a bolt in it to withdraw it and before and after cleaning, Jan 2019 ish.
Good shout :)
viewtopic.php?f=4&t=191108&p=1632341
Postby cherniy_chack » Tue Jul 06, 2021 5:55 pm
Hello camper-man.
I realized that you bought the car recently.
I think the reason the car doesn't want to go faster than 50 mph is because the rear axle has a 5.14 gearbox for a type 34 axle or 5.83 for a type 53 axle.
cherniy_chack
Postby npjrogers » Fri Jul 09, 2021 6:17 pm
I have a mk5 non turbo (non banana) 96 camper. It is a 75ps. She has not been tweaked but she has a new timing belt and I made sure to loosen the pump sprocket after making sure all the other gears were pinned. Also made sure no air was leaking into the fuel filter. She has an MT75 close ratio 3.89 transmission. She will happily reach 60 on the flat. I also put 2mils per litre of low ash two stroke oil (B&Q) to keep the injectors sweet. She has also had a Terraclean. I am getting around 37 MPG. Feel free to message me if you want to chat.
Sic Transit Gloria
npjrogers
Postby cherniy_chack » Tue Jul 13, 2021 5:56 pm
37mpg is great fuel economy! 3.89 gear ratio is in the rear axle gearbox. Rarely lucky to have such a gearbox.
I had 4.11, but the teeth fell, I had to install the most common 4.56.
Fuel consumption is approximately 7.5 l / 100 km or 31 mpg.
The machine is 90 years old, the turbine was installed in 2015, in 2017 a fuel pump with a turbo corrector was installed.
How many times did it accelerate to 140 km
hour or 88 miles per hour.
My usual speed on country roads is 85 km / h, about 53 miles per hour.
cherniy_chack
Postby MinorMatt » Wed Jul 14, 2021 8:30 am
cherniy_chack wrote:The machine is 90 years old,
errrm???
My 93 year old pickup gives mid 30 to the gallon, but its only used about half a gallon in total this year.... :lol:
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Noctule » Wed Jul 14, 2021 10:11 am
cherniy_chack wrote:Fuel consumption is approximately 7.5 l / 100 km or 31 mpg.
That's for a US gallon!
In the UK 7.5l/100km is around 37-38mpg.
Mat
https://www.calculateme.com/gas-mileage ... per-100-km
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby cherniy_chack » Thu Jul 15, 2021 4:55 pm
Thank you,Noctule
A person from the world of metric measurement does not see the difference in the British gallon and the American gallon.
For us, this is about the same as the Ukrainian pood and the Russian pood.
And the pood as he was, is 16 kilograms! :lol:
cherniy_chack
