by TransitSi » Fri Jun 25, 2021 4:40 pm
Small update.
So old thread was gone because transit had been sat for ages in storage, and during the time in storage someone had taken a couple of small misc parts off the engine and also broke the adapter that goes into the head, so we tried to get it out but it was in real bad shape and just would not budge no matter what we tried. So the only option was to drill out the thread but in doing so killed the thread inside.
So i went and bought a 16mm /1.5 tap set and got some old steel and tried it out on that first and it was just ever so short off what was needed for the adapter to screw freely into the new tapped thread in the steel so i went to another shop and took the adapter and bit of steel i tapped with the 16mm and had a word with the bloke there after sizing up with a couple of taps the 11/16 looked the best for what was needed.
Drilled another hole into abit of steel and then tapped it with the 11/16 and tried the adapater and bingo, its worked. So now to take it to the head and hope i get the same outcome!
