MinorMatt wrote:The injection pump itself has no coding.
I have had this in the past - admittedly I didn't spend too long trying to bleed it through but ended up changing the pump again to get it going
Was the cambelt all pinned up correctly?
Catman47 wrote:After part removing passenger side dash to get access to ECU low and behold ….no power also to it. We found evidence of vermin droppings and some chewed loom so we must have a live feed to the ECU from the fuse box has been compromised. We just need to find the break in the circuit……..replace the relays and fingers crossed she will fire up.
Catman47 wrote:Hi Matt
Auto electrician came out today and sorted out the electrics and other problems. He found a faulty relay in the fuse box near to pump in engine bay the exact one you mention…….we then had power to ECU and power feed to pump. He connected up to diagnostic scanner and cleared a few codes and got all electrics working ok.
He discovered a sealing rubber O ring on the feed pipe to the pump was faulty and replaced that and bled the fuel system with a hydraulic pump. After checking with quick start she fired up but we now suspect the ESOS valve could be faulty and needs a new one ……I will remove it tomorrow.
We may refit the original pump that we know was working fine until the electrics, relays, etc went mental. Seems that the mechanic wrote off the original pump before a full check of electrics mentioned above.
Lastly Matt I have heard that the timing needs to be advanced on the pump sprocket for a Turbo engine…..is this true.
Thank You so much for all your guidance thus far
Kind regards
