Hi frankieboy231.
If you remove the front door and open the hood, you can drill out the fender-to-body weld points and remove it.
The view will reveal a terrible picture of body corrosion hidden by the wing.
So your garage doesn't want to do this.
Without welding, damaged parts are difficult to fix, but you can.
Repair inserts can be installed on rivets, small bolts with nuts or self-tapping screws for metal.
https://encrypted-tbn0.gstatic.com/shop ... Q&usqp=CAcIt is better to adjust the relative position of the repair inserts and the wing with self-tapping screws for metal.
After fitting, the new wing can be attached to the body with metal screws.
When the son broke the wing, I quickly installed the wing on self-tapping screws for him, he sold the car, and they broke the wing, I also installed it on the self-tapping screws before repairing.
