I've just taken my mk3 transit derived motorhome for it's maiden voyage and it was really struggling to get to 50mph even on a flat road. Going into 5th and it can't cope and falls to 45.
I've heard people tweaking the fuel injection pump, however when looking in the area it doesn't seem like I am using the full amount of throttle position?
It looks like when the throttle is between 0-50% I can see the mechanism working the part on the right is pushed away to open the throttle. Once the cable is past 50% the mechanism is rotating but no longer pushes that part any further out, presumably throttle remains the same.
If I understand correctly, if I loosen the 2 nuts and adjust the metal piece I could then adjust the amount the throttle opens in relation to the pedal? And that currently it is simply not opening all the way.
Or am I way off with this
