V184 wrote:if you turn the lights on you can get your head where the pedals are & see behind the dash you can change them without removing anything
dumper wrote:Now this may not apply to a mk3 but on a mk2 I had one with poor dash lights that had a blue lens that the bulbs shone through and the heat form the bulbs discoloured and turned them brittle what I did was remove them and instead of a blue light it gave a brighter light not sure if I had to strip the cluster to take the lens out
dumper wrote:Yes leds would be a very good modern move when I did the mk2 probably not been invented
