Mk 5 spare wheel carrier
Postby CCCars » Mon Jul 26, 2021 7:59 pm
We recently bought a Transit based 1999 Autosleeper Duetto, after getting home we discovered it didn't have a jack or any wheel changing equipment, also front wheels had security nuts but no sign of the adaptor!
Anyway this is where I am now, after removing the rear bumper to lower the spare wheel to the ground I discovered that the spindle of the winch thing is damaged so I removed the spare wheel holder to take a closer look, the end of the spindle seems to need an 8 sided socket to operate it?
The jack handle I bought has a square knob on the end so that's no help.
I had to remove the rear bumper because the tow bar which was fitted had pushed the bumper up making access to the hole to wind down the spare wheel impossible, as I have no intention of towing anything I've removed the tow bar and made a step to help access via the rear doors.
I need details of the tool needed to wind the spare wheel up and down in case of a puncture please.
Graham
CCCars
Re: Mk 5 spare wheel carrier
Postby angusp » Mon Jul 26, 2021 9:28 pm
It should be the square section on the end of the jack handle! Maybe you could upload a picture of the spindle assembly?
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Postby CCCars » Mon Jul 26, 2021 10:13 pm
I'll try to get a picture in the morning.
Graham
CCCars
Postby Noctule » Mon Jul 26, 2021 11:00 pm
The tool should look something like this...
it also fits in the jack.
The hole in the square isn't always there, I've had mk5s with and without it, the current mk5 defintely needs the hole.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby MinorMatt » Tue Jul 27, 2021 9:11 am
All mk5 jack handles have the octagonal recess for the spare wheel hanger
But mk4 ones don't - they relied on the square drive. The mk4 version is far better in my opinion.
The square on the mk4 jack is also smaller, so you can't use a mk4 jack with a mk5 or vice versa
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby CCCars » Tue Jul 27, 2021 1:05 pm
Here we go, first attempt on this forum!
Hopefully it will appear?
I've removed the locking lever to get a better look at the spindle, as per the reply my jack handle only has a square but no octagonal recess so looks like I have the wrong handle :roll:
I also seem to have the wrong jack as mine has an attatched handle instead of a square socket :(
Does anyone have the part numbers for the correct items?
Many Thanks
Graham
CCCars
Postby CCCars » Tue Jul 27, 2021 1:24 pm
If it helps the square on my jack handle measures 18mm across the flats of the square.
Graham
CCCars
Postby MinorMatt » Tue Jul 27, 2021 2:22 pm
I believe this is what you need - but ask the seller to confirm it has the recess
https://www.ebay.co.uk/itm/324591740888 ... SwxslghsNa
93 L GL Minibus
Postby CCCars » Fri Jul 30, 2021 12:47 pm
I managed to track down the part number and found a new one from Rates Ford so will need to carry my spare in the van for now :( the boss is not impressed but if I put it back under the van we'll be sure to get a flat and not be able to get it down without taking the bumper off so I can get my socket bar in and it will be sure to be pissing down as well!
Graham
CCCars
Postby CCCars » Wed Aug 11, 2021 5:25 pm
So far I have the jack but no handle and an 8 sided 15mm socket so I can wind the spare down if required, will have to take a trip round the breakers and see if I can locate a handle, I fitted new security nuts to the wheels and injected puncture preventative into the tyres so hopefully I won't need any of this kit but who knows!
Graham
CCCars
Postby meterreader » Mon Aug 30, 2021 9:13 am
Where abouts are you? I have one in townsville Aus that you can have if desperate.
meterreader
Postby CCCars » Thu Sep 23, 2021 9:51 pm
meterreader wrote:Where abouts are you? I have one in townsville Aus that you can have if desperate.
I'm in the UK so postage might be steep!
Thanks anyway.
CCCars
