00353theking wrote:If you have a 6 stud axel you remove the halfshaft relase the brakes from the back and the brake drum will come off , the 5 stud axel is different i cant remember, put a picture of the axel up so people can see and give you advice
Sent from my SM-G965F using Tapatalk
Heathen wrote:It's a 6 stud.
I can't start dismantling until I know that I'm able to reassemble to the right torque settings (my wrenches have a max torque of 350Nm).
V184 wrote:You dont need to remove the hub to get the drums off, remember to mark the wheel/drum to hub otherwise you could end up with brake judder
Well the 6 stud axel on the back of my van the half shaft comes out first , mabey there are other variations of themMinorMatt wrote:00353theking wrote:If you have a 6 stud axel you remove the halfshaft relase the brakes from the back and the brake drum will come off , the 5 stud axel is different i cant remember, put a picture of the axel up so people can see and give you advice
If its a 6 stud single wheel you can't get the half shaft out until the drum is off
Heathen wrote:V184 wrote:You dont need to remove the hub to get the drums off, remember to mark the wheel/drum to hub otherwise you could end up with brake judder
So you're saying that I don't need to remove the hub to remove the drums - that's in contrast to what the Haynes manual reads, but I'm gathering that that's no surprise.
Regardless, if someone could help translate the specifics of my van (axel type etc), it would help me in future work, torque settings etc.
Heathen wrote:Nevermind, I managed to get inside the Drum.
Braking surface seems even and smooth.
Brake shoes are also smooth. However, they're uneven. Could this be causing the juddering and locking up of the wheels?
I did check LAV, with engine running and brake pedal being pumped. It consistently moves about 5mm-10mm...although, creaks a little bit.
