MinorMatt wrote:Valves are never bent... (well you would have been extremely unlucky)
The push rods bent, and frequently the rockers snap too - is this what you mean?
After you replaced the components, did you set the valve clearances?
Mattyone wrote:MinorMatt wrote:Valves are never bent... (well you would have been extremely unlucky)
Sorry yes the push rods bent I adjusted the valves before trying to start
4 rocking adj 1
3 rocking adj 2
1 rocking adj 4
2 rock adj 3
is the above correct way
MinorMatt wrote:https://fordtransit.org/forum/viewtopic.php?f=31&t=9565
dumper wrote:From memory I can’t think of any other 4 cylinder engine that the one from nine sequence doesn’t work.
