dumper wrote:Have you got the crankshaft locking pin in the correct hole in the flywheel I’ve never had this problem but the wrong hole is not as deep as the correct one.
Keef wrote:You have got 12v to the pump stop solenoid?
Just wondering if you've broken the wire or dislodged it doing the other work.
dumper wrote:Up until a couple of years ago before I retired I was under the impression that to ge fuel out of the injection pipes when they we're cracked off that you only got fuel out of them when the pump was turning over and ignition on but I was fitting a Bosch 6 cylinder pump to Cummins engine which looked like a transit pump but 6 cylinders and I was under the bus operating the life pump to prime the low pressure side or the system and I had diesel running down from above I was thinking that I hadn’t connected something up but on investigation the diesel was coming out of the loose injection pipes so fuel can come out of the injection pipes with no 12v feed to the stop solenoid as they say after this every day is a learning day.
MinorMatt wrote:The stop solenoid on this pump should not have 12V on it! It is a operated via a pulse width modulated signal and a constant 12V across it could kill it.
marcrbarker wrote:According to my understanding whether there's PATS or not, if the injection pump is a Lucas EPIC (i.e. DSA1190/1191/1096 etc) the 'stop solenoid' is used to stop the engine when the key turned off. If it's this and you want to check the feed to the solenoid , the wire colours are violet/ brown and black/red. It's around 5 V when valve energised. Just simply applying 5 V wouldn't work to open it, because the valve needs a short 12 V pulse to shift the valve into place and 5 V to hold it there.
A diagnosis to prove there's compression and the valve timing is OK, You can start and run an diesel engine on spray brake cleaner down the air intake, usually for up to a minute before the clacking noise gets unbearable to hear. This feed completely bypasses the injection pump, fuel filters, injectors, ECU, stop solenoid, everything. Go easy on the spraying because you can over-rev the engine. Don't do it for too long because the smoke is annoying to neighbours and it condenses on car windscreens you won't be popular.
Edit. also a squirty-bottle garden sprayer filled with white spirit or turpentine works too. Aerosol brake cleaner is the easiest
Keef wrote:marcrbarker wrote:According to my understanding whether there's PATS or not, if the injection pump is a Lucas EPIC (i.e. DSA1190/1191/1096 etc) the 'stop solenoid' is used to stop the engine when the key turned off. If it's this and you want to check the feed to the solenoid , the wire colours are violet/ brown and black/red. It's around 5 V when valve energised. Just simply applying 5 V wouldn't work to open it, because the valve needs a short 12 V pulse to shift the valve into place and 5 V to hold it there.
He's already posted a video with it running from a spray and its a Bosch pump anyway.
