marcrbarker wrote:The 'paperclip trick' finished that long ago 1994? THought it was later. Wow. PLunger rubber end completely dissolved away with nothing trapped in a filter? That's really neat how they do that, if the bits are small enough to get past a filter I expect it'll pass through an injector just as well, probably give the injector a good clean on its way out. What I STILL find peculiar is there's no replacement plunger rubber at all in the kit of seals. They include all the outside plastic blanking caps for lazy pump rebuild shops, but the kit omits the very part that dissolves away the most.
I haven't been able to get across town to the van to try the stall test yet. I am still curious most of all to know if this gentle but annoying 'kangarooing' is a part of the limp mode. If the ESOS failure limp mode can be easily cleared by stalling (how ever many times needed to clear that DTC) then I might not even bother putting the plunger back in the pump, just leave it out completely while I mess about with the injection timing advance 'on-the-fly' I've planned later for this week. I'd rather not start any more mechanical interventions just yet until I've investigated enough first.
the light probably stays on for 5 seconds before going out? If it goes out immediately the fault code memory is clear - if it doesn't there are either "minor" codes stored (e.g. EGR) and/or historic/resolved codes which haven't been cleared from the memory.The light staying off also means there's likely no other faults.
MinorMatt wrote:Has the stalling trick got rid of the "kangarooing"?
MinorMatt wrote:If you advance/retard the timing more than +- 4 degrees (iirc) it will go in to limp mode.
MinorMatt wrote:There are some small locking bolts on the front though, which I am fairly sure allow you to physically adjust the timing without altering the "pinning" position.
MinorMatt wrote:I havent worked out what the calibration resistor calibrates yet - but I have had reports of a noticeable, but not massive, improvement in power by fitting a number 15 resistor (100 ohm +-5) in place of whats fitted. .
MinorMatt wrote:Have you found the LDV lucas EPIC manual? There is some useful info in there - if not search for "Ecovippari EPIC" on google
MinorMatt wrote:on for 5 seconds before going out? If it goes out immediately the fault code memory is clear - if it doesn't there are either "minor" codes stored (e.g. EGR) and/or historic/resolved codes which haven't been cleared from the memory.
MinorMatt wrote:I don't know what diesel is like there, but EPIC pumps arn't very keen on low Sulphur fuel - the advance CAM ring in the pump needs the lubrication the sulphur provides, and then it goes sticky and causes limp. Its recommended to add extra lubrication (normally mineral 2 stroke oil) to the diesel to prevent this.
I'm interested to see where you go with this
It's a continual regular oscillation in engine torque, always at 2.5 Hz, so I'm pretty sure now it's an artefact of the engine management system. Suspect it's resonance in the injection quantity servo loop triggered by a weak cylinder. If it is then I expect lots of other Transits will do this too
The pump drive pulley bolts between them the pump timing pin hole? I might be wrong on this but I wouldn't expect offsetting here would have any direct net effect on timing at all, otherwise people would use it to fiddle with the timing. Instead I expect moving pulley position like this would just alter the PWM operating range the ECU needs to command to get the programmed cam ring placement coming back on the 0-5V analogue signal. Rather like AFC on a FM radio, you move the tuning dial slightly back and forth and nothing much happens. Anyway, my objective is change timing on-the-fly with a turny-knob thing in front of me while climbing a hill. Do it electronically and keep all mechanical interventions to absolute minimum.
I strongly suspect the calibration resistor is just a sticker they put on afterwards to represent how much residual error is left after manufacture and testing, to tell the ECU how much to trim off or add to static timing. It's that primitive.
I would expect the ECU only ever reads the resistor the once, during initialisation after a power-on, very unlikely the ECU would poll it for change while running.
Yes found the LDV info. Also saw Ford Training etc. that's claiming to be hosted for download in lots of fake discussion forums and fake filesharing sites, obviously it's for harvesting credit card numbers from people searching on google. I didn't bother with those.
The light goes out 5 seconds after start. The EGR was blanked off long time ago and the mechanism still moves ok. I'm pretty sure the ECU can't tell it's been blanked off (by looking for a MAF dip) because there's no MAF I can see. I suspect the stored codes causing the '5 seconds' will clear by themselves after long enough without events, unless I forget to stall the engine and spoil the history. If I keep doing that I'll need to refit the stop plunger.
I think it's the exact same "gasoil" (diesel) that's on mainland Spain. It's very unlikely anyone here would had habitually added twostroke oil, the lifestyle here is free and easy. There's an epidemic here of rusted out core plugs and bypassed failed cabin heaters because many people never heard of antifreeze, though having said that they are marketing it more nowdays as 'refrigerante para verano' = summer coolant. I'll ask around and see how well known it is.
MinorMatt wrote:
its 3 or 4 very small (m4 maybe?) cap headed screws - but as you say irrelevant to what you are trying to do.
MinorMatt wrote:
It will be to take up a manufacturing tolerance, the rotor position sensor (position of the rotor dictates fuel quantity injected) is shimmed, but I think thats the only sensor that is. The Hall sensor has adjustment by slots for the screws
MinorMatt wrote:
I have got some Lucas training manuals on the EPIC - I will see if I can find them - there may be some useful info.
MinorMatt wrote:
Its recommended to add extra lubrication (normally mineral 2 stroke oil) to the diesel<snip>
I was more advising to check the diesel you have (its called city diesel here) and add some extra lube if you need too.
MinorMatt wrote
It will be interesting to see if it all works, its taken a few minutes to get my head around what you are proposing - im not entirely convinced it will work, but there is only one way to find out! I have obtained extra power on one of my vans by shimming the rotor position sensor rod - but that increases the revs at idle and if you take it too far it goes in to limp.
MinorMatt wrote
The other thing I think would be beneficial is to modify the boost sensor so that it is tricked in to injecting more diesel by reading a higher boost lower down the rev range - putting an offset in a bit like you are doing with the timing.
If you want to mess around inside the ECU - I will happily send you one to experiment with?
