I've got an update about the plunger repair. This is the ESOS thing, a finger-pokey thing valve shutoff thingy operated by one of the back mounted solenoids. It's supposed to open and shut when you turn the engine on and off. It's supposed to have a rubber end but it dissolves away and dissapears without a trace. I'd previously put a new rubber end made out of a blob of automotive silicone and shaped.
Well I didn't feel happy with it so I'd caught up with the van and removed the plunger again which is quick and easy as there's no cover on the injection pump. A good job I did because the rubber was starting to swell which would be fine if it was a gasket but it's not desired here as it's a moving part.
The plan is to try get a replacement or order one online.
In the meantime I've made a much better version that would probably out-last the proper original - use for time being. So here is step by step guide how make one for next to nothing and that's probably better.
Start off with an offcut of viton o-ring 8 mm diameter. Must be viton don't use neoprene or nitrile and don't even think about using isoprene, butyl etc.
Cut straight with razorblade a 3 mm flat disc. Put a taper profile on one end.
Get the plunger and carefully put a nick into the cone shaped end with wire cutters. This is needed later.
With the rubber disc, non tapered face, cut a partial hole in dead centre of with a sharp 2 mm drill taking care not to perforate it completely
Then press the disc firmly over the cone shaped end making sure it goes into the hole. Now while maintaining pressure twist the disc around so that the nicked metal part cuts a recessed taper shape into the blind part of the hole, so it makes a secure retention.
Place the finished plunger standing up on a mirror
to check the seating face is flat and perpendicular. I can't post more than 5 images to show end result but finishing touch is a pinhole through the centre.
Looks quite good and the end is very well secured. When the van is back in town long enough I'll fit this plunger while trying to find a new one.
