by MattR140 » Mon Aug 30, 2021 1:45 pm
Hi Guys new to the site, wondering if anyone can help me? currently doing a bosch conversion on my 2.5TD, I'm using a 150 pump, not sure if this is the correct pump to be using, with timing adjusted for the turbo 0.68mm fuel screw up quarter turn, not sure if this needs adjusting more? there is fuel squirting from the injection pipes but doesn't seem like enough pressure. it has the 100hp injectors and there obviously isn't enough pressure to make these fire as the is no hint of the engine trying to fire. Anything I am missing? will this pump even work or am I flogging a dead horse? any help would be greatly appreciated, cheers
