Hi, we recently bought a 10th hand Ford transit auto sleeper and had a few away trips with it, but then we started having an issue with the accelerator. It will start and we can drive it for a short period but then the accelerator cuts out and it only coasts along. If we switch it off and on a few times the throttle will kick back in for a short bit but then cut out again. I am not sure we would even be able to drive a mile with it.
We had someone run computer diagnostic on it and they proposed it needed a replacement drive by wire throttle pedal - however we have not been able to find one anywhere. Another mechanic suggested it could be the wiring into the injector pump and to look at a replacement epic diesel pump. Can anyone give us some advice as we are not mechanics and are struggling to know how to solve this?
