marcrbarker wrote:Just to add Because sometimes a EGR valve doesn't shut I've often seen these valves simply blanked off with a scrap of tin plate cut out from a can of cooking oil. I've even seen cocacola and beer can metal used. Mechanics younger will sometimes say "you can't do that to EGR because the engine loses power / limp mode" but this model ECU doesn't know the EGR valve (or butterfly valve) are disabled. It only knows it's electrical connector is plugged in and nothing more.
Altransit wrote:You can disable the EGR valve by simply cable tying the flap in the open position, and disconnecting the actuating rod.
If you have oil leaking from the rocker cover, there could be a problem with this excess oil being burnt and causing the black smoke. This problem is usually caused by a missing 10mm headed bolt which normally blocks off an oilway under the cover in the area of the rocker shaft.
Altransit wrote:Yet we still don't know (because the OP hasn't told us) whether it's a turbo engine or not.
The majority of these Di engines were N/A, in which case, there is no electronic control of the EGR.
joek009 wrote:Altransit wrote:You can disable the EGR valve by simply cable tying the flap in the open position, and disconnecting the actuating rod.
Hi
Sorry for the crazy slow reply been on holiday. Had a read through what everyones said sounds like bypassing EGR is the best way to go. Is it terrible for the enviroment to do this though like am I going to be emitting more CO2 and be less efficient with fuel consumption?
dumper wrote:Not another tree hugger don’t worry China is kicking out more co2 then we could in the next 50 years also if you are worried about it why are you running about in a mk 5 .
dumper wrote:Al don’t knock coal power
Users browsing this forum: spacecabbie
