marcrbarker wrote:These Diesel engines are so sttong
marcrbarker wrote:
There is a rough and crude cylinder compression test can do without tools but it's a tricky to do. It's stop on a steep slope facing downhill and then with key off, handbrake off, in 3rd gear and clutch up, roll forwards and listen and feel each compression stroke.
It would tango lurch forward slow-slow-slow-quick-slow-slow-slow-quick...r.
marcrbarker wrote:
About the crude no tools compression check, the idea is similar to manually turning the crank around with a 19mm (you should feel a springy compression every 180 degrees turn of the crank).
MinorMatt wrote:Does it smell acrid or of not very much?
jimllshiftit wrote:Two fairly easy checks id be tempted to do in the absence of a compression tester is take the rocker cover off and check for push rods, rocker arms and valve problems. ..... id also be tempted to check the timing.
A proper compression test will answer an awful lot of questions for you though.
mkgld wrote:MinorMatt wrote:Does it smell acrid or of not very much?
Thanks MinorMatt for chime in!
I think it doesn't smell that bad.. just a little more like diesel than usual, and in bigger quantities .
