Thanks to you all.
I've tried to measure the amount of diesel of each cylinder, but I failed.
I couldn't remove one of the injectors, the one of the back.
So I tried another thing, with the engine on, I started to bleed each injector and I noticed that when I lose the tube of the injector that it is stuck, the smokes stops.
Also noticed that the sound does not change bleeding that injector, but when I bleed the others it is more noticeable the difference. Especially bleeding the second and the third injector. With the first one, the sounds changes, but not that much.
I've made a video showing it.
https://youtu.be/sMfXT_ryyDECould this mean that the problem relies on that cylinder?
How silly is my hope that the problem is an injector?
Isn't possible that the water broke one injector before breaking the rod?
Tomorrow I will try again to remove that injector. I am also talking with a mech to come to have a look at the van.
In the meantime, finally today I found one engine from the scrap, it is the first one I see online.
They ask 1000 Eur, it has 150000 km, they say it worked good before they removed it.
I am still a little afraid of buying a new engine without knowing if it is going to be in good shape, but it may be the only way out.
