Radio code
Radio code
Postby slogger » Thu Oct 21, 2021 1:02 pm
Could someone tell me my code .It is a ford 3000 fitted to a smiley 2000 year the code on the radio is Serial no M044098 part no 97fp-18K876-LA or direct me to somewhere legit that I can pay a small fee and retrieve it
slogger
Re: Radio code
Postby MinorMatt » Thu Oct 21, 2021 2:45 pm
If nobody else does... I will post it up later when my phone has mobile signal
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Re: Radio code
Postby slogger » Sun Oct 24, 2021 1:48 am
MinorMatt wrote:If nobody else does... I will post it up later when my phone has mobile signal
Thanks i would appreciate it
slogger
Re: Radio code
Postby Keef » Sun Oct 24, 2021 1:27 pm
Keef
Re: Radio code
Postby slogger » Sun Oct 31, 2021 1:13 pm
Thank you very much for that .You are a star
slogger
Re: Radio code
Postby Wipeout » Thu Nov 11, 2021 7:23 pm
HI!! Hope maybe someone can help me...
I bought a 97 smiley with the 3000 traffic radio, and since I bought it the radio was asking CODE.
I was cleaning the van today and find this on the drivers side below the seat belt column.
So I tried the code, and didn't work...
Can be radio was changed ? Or is this another code for another thing?
Thanks for any help!!
Wipeout
Re: Radio code
Postby Jas278 » Thu Nov 11, 2021 9:20 pm
You need the Serial number off the unit , begins with M , then you can get the code for free..
Jas278
Re: Radio code
Postby Wipeout » Thu Nov 11, 2021 10:29 pm
Jas278 wrote:You need the Serial number off the unit , begins with M , then you can get the code for free..
In the sticker I found it says : M000434
Also says UNIT TYPE : FD 3000...that means the 3000 traffic radio?
Wipeout
Re: Radio code
Postby Jas278 » Thu Nov 11, 2021 10:39 pm
Code 1275
Jas278
Re: Radio code
Postby Jas278 » Thu Nov 11, 2021 10:41 pm
Thats the code off the sticker ! you need the one from the unit itself !!!!!!!!
Jas278
Re: Radio code
Postby Wipeout » Fri Nov 12, 2021 12:05 am
Jas278 wrote:Thats the code off the sticker ! you need the one from the unit itself !!!!!!!!
Yes I’m sorry!
So I took the radio out finally…and the serial number of the radio is :
M015222
Thanks so much ! (The sticker must be from the original radio unit, and at one point was changed for this last one..)
Wipeout
