CCCars wrote:Todays update, loaded the free app connected successfully with the ELM327 and came up with the following fault codes:-
P0400 EGR System malfunction, could be EVR solenoid if that's the one that controls the EGR valve as that's not working correctly.
Will put light on for 5 seconds at start, but not limp - entirely possible its the solenoid
P0105 BAP sensor circuit, Barometric Atmospheric Pressure.
0105 - Boost Sensor, Will cause limp mode - check pipe between inlet manifold and sender, if no obvious fault, replace the sensor
P1300 Boost Calibration Fault ?
Boost Calibration, Will cause limp mode - check pipe between inlet manifold and sender, if no obvious fault, replace the sensor
B1682 PATS is disabled, because engine started and running?
Ignore this one - it won't cause the light to come on
P1109 Intake Air Temperature 2 Circuit Intermittent, connectors or intermittent open/short circuit or sensor fault..
1109 - Boost Sensor Low
P1302 Boost Calibration Low ?
See Previous boost ones
I'm guessing PATS is disabled once the engine has been started so B1682 is just for information?
P0105 P1300 and P1302 I guess would affect performance?
Where is the intake air temperature sensor located, guessing somewhere on the air intake? Is there any way to test it?
P1300 and P1302 refers to a procedure in the service manual to identify the fault, anybody got the manual? I've only got a Haynes book.
Any help would be much appreciated.
Graham
