motor / engine compatibility
Postby erposti » Mon Mar 14, 2022 2:57 pm
Hi there,
I am new to the forum and this is my first entry.
I have a Ford Transit C-1086 2.5 D van purchased in 1998.
Unfortunately the engine has died. It is a type D / 4FD engine.
Finding the same type of engine is practically impossible, but in scrapyards near my city I can find second-hand ford transit 2.5 D engines but of the 4FB or 4HC type.
My question is: Can I mount a 4FB or a 4HC to replace my 4FD engine? Is there compatibility or will the mechanic have problems?
When I see the motors from the outside, they look almost the same, but I don't know if they are really compatible because I'm not a mechanic.
If they were compatible motors, which one do you recommend? 4FB or 4HC?
Thanks in advance.
This is my first post, if I've made any mistakes, I apologize.
I've had my broken down van for 3 weeks, I really need it and I'm desperate.
I hope you can help me.
All the best.
erposti
Re: motor / engine compatibility
Postby MinorMatt » Mon Mar 14, 2022 4:53 pm
a 2.5Di is a 2.5Di...
If you can get an engine from 1997 onwards it will fit straight in with no bother (do you have a factory immobiliser? Theres a red bit on the key, and an LED in the dash/roof if so)
If you get a 1991 onwards engine, it will fit with no problem, but there are some parts which will need to be swapped from the old to the new.
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby erposti » Tue Mar 15, 2022 2:51 pm
Thank you very much really
Now I know that I can buy the 4HC engine and install it in my van with no problem. Luckily it doesn't have the immobilizer.
3 weeks without knowing the correct answer and in this forum I get it in 3 hours.
erposti
Postby nicoelburg » Fri Oct 28, 2022 11:32 am
Hallo beste Lezers ,
Ben helemaal nieuw op dit Ford forum mijn naam is Nico ben in bezit van een Ford transit 1991 camper van Reimo. 2500 diesel.
al 8 jaar in gebruik geheel overgespoten in sep 2022 alle laswerk is klaar en oliebad gehad.
Mijn vraag is ik heb al 4 jaar een 2l dohc motor115 pk klaar staan en ik ga heb inbouwen alles staat klaar
behalve de motorsteunen weet iemand het type steun wat past zijn ooit geleverd vanaf type transit 1994 .
alvast bedankt gr Nico.
nicoelburg
Postby Chug » Fri Oct 28, 2022 8:13 pm
erposti wrote:Thank you very much really
the 4FC is the same output (70HP) as your 4FD fitted from 95 - 00
the 4HC is 76 HP output fitted from 94 -00
Chug
Postby Chug » Fri Oct 28, 2022 8:16 pm
nicoelburg wrote:Hallo beste Lezers ,
this is mostly an English language forum ........... Google translate https://translate.google.co.uk/
Hello dear Readers,
I am completely new to this Ford forum my name is Nico I own a 1991 Ford transit camper from Reimo. 2500 diesel.
been in use for 8 years, completely repainted in Sep 2022, all welding is ready and had an oil bath.
My question is I have had a 2l dohc engine 115 hp ready for 4 years and I'm going to install everything is ready
Except for the engine mounts, does anyone know the type of mount that fits and have ever been delivered from type transit 1994.
thanks in advance, Nico.
you can find details here
https://www.transitcenter.uk/engine-mou ... -5013.html
https://www.transitcenter.uk/engine-mou ... -5014.html
Chug
