Mk5 Transit - Multiplug For Rev Counter
Postby PIO » Mon May 02, 2022 9:04 pm
Hi All.
Putting a Mk5 Rev Clock Cluster into my Mk5 Camper. My Multiplug is a low series loom and therefore does not have the wire/connector for the Rev Clock.
Any trick for getting/inserting the metal terminal into the multiplug to run the Rev Clock.
Don't suppose anyone has a spare multiplug for a Rev Clock Cluster that don't want.
Much appreciated.
Michael.
PIO
Re: Mk5 Transit - Multiplug For Rev Counter
Postby Noctule » Mon May 02, 2022 10:42 pm
The top of the multiplug pops off easily, all you need is a crimp with a bit of wire on to attach your wire from the alternator to. If your clocks have a bulb you don't use and the wire is in place for it (eg engine warning light when you have a Bosch pump) just swap its position. Push it out from the bottom, you'll then have to bend back the little tag in the middle that holds it in place.
Mat
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby PIO » Tue May 03, 2022 9:53 am
Thanks a Mil Mat...
Much appreciated.
Tried before to remove one but perhaps a little bit more pressure from the bottom will shift it out.
I'll try that.
Michael
PIO
