Ignition switch Feed to coil?
Postby mikec » Mon Jun 27, 2022 7:20 pm
Is the ignition switch a known issue on a late 93 transit pinto? I am trying to chase down a volt drop to the electronic ignition coil or is there a relay somewhere. If they are where is the best place to get one.
mikec
Re: Ignition switch Feed to coil?
Postby Altransit » Mon Jun 27, 2022 7:56 pm
What voltage are you getting to the coil?
