Epic Multiplug removal
Postby Dave2504 » Fri Jul 01, 2022 3:22 pm
Hi All
After studying a lot of topics on here, I invested in Forscan and the ELM 327 from Tunnelrat. I have the 97 Smiley TDi.
Engine warning light came on a few weeks ago.Off and on.Added diesel treatment etc seemed to settle down, but now on permanently.
Ran Forscan and codes: P1644 Fuel pump and P1189 Pump speed sensor\wiring fault.
Need to check multiplug connections (seen on here water and corrosion can be issue).
Question is how does the plug come off the Epic pump? Is it twist and pull? Seems stuck.
Dave
Dave2504
Re: Epic Multiplug removal
Postby MinorMatt » Sat Jul 02, 2022 8:28 pm
Push the red tag in and twist
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Dave2504 » Mon Jul 04, 2022 9:16 pm
Hi Matt
Thanks for your reply. I can't see a red tag, could it be the white one? Photo attached
Dave2504
Postby MinorMatt » Thu Jul 07, 2022 9:29 am
Yes it would be the white one...
93 L GL Minibus
Postby Dave2504 » Tue Jul 26, 2022 3:28 pm
Thanks for your help Matt.
As suspected, water in plug and corroded contacts.
One pin broke off. Managed to reconnect it.
Cleaned them up.
Limp mode light now off. Been OK now for a week.
Happy days.
Dave
Dave2504
